Text engraving and UDF
I would like to create an UDF for engraving text but I didn't find the way to store the choice of the text inside the UDF even with string expression. Is it possible with NX8.5 ?
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Text engraving and UDF
The ability to include a 'String' expression in a UDF is not currently supported.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi UGperson
Thanks for your example. that's what I was going to do. Could send an image to understand the question to place the UDF ?
Didier Psaltopoulos
I was assuming that DidierPSICAD wanted to edit the value of the 'String' Expression as part of the workflow while adding the UDF to the model. Granted, once the UDF has been added to the model the 'String' expression can be edited, but it will not be seen as part of the 'definition' of the UDF itself.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
For this UDF to work you need a datum csys, a solid and an expression called "TXT1" etc. Make sure that the expression is set to string.
once you have all of that activate the UDF.
1. Pick the center point of the datum csys.
2. pick the surfaces the text is to be placed on.
3. pick the solid.
when it is done the text will be trimed and then united to the solid.
Hi UGPerson
Thanks a lot. I have tried it on many parts. It's wonderful
Didier Psaltopoulos
