Microsoft Visual C++ Debug library
Hi all,
I have an issue, I have one code developed using prottolkit in C++ sln file which I need to upgrade from pro-e 3 to pro-e 5(CREO-5). It is an asynchronous application.
I am using Visual Studio 2008 with .Net frame work 3.5 with SP1 on Win7 for CREO-5. I am able to build the code in Debug and Release mode. In debug mode I am unable to debug the source code. It is showing one error message before hitting the breakpoint in code. I have tried all the possible options googled.
I want to know whether it is an compatable issue or issue with my visual C++ debugger.
The error message is "the application has made an attempt to load the c runtime library without using a manifest". [b]The application is unable to start correctly (0xc0000142).Click OK to close the application. Please find the sanpshot of the error message "http://files.engineering.com/getfile.aspx?folder=6...".
Please provide a solution and if any questions let me know.
Purna
