Help on shape violating errors
Hi all,
CAn anybody please look into the errors coming in this code? Please suggest something.
PS. I have already asked this type of question in this forum but I need to figure out the problem. I tried but I am not getting any help from anywhere.
CODE --> ansys
!* /PREP7 !* ET,1,PLANE183 !* KEYOPT,1,1,1 KEYOPT,1,3,3 KEYOPT,1,6,0 !* ET,2,PLANE183 !* KEYOPT,2,1,1 KEYOPT,2,3,3 KEYOPT,2,6,0 !* !* R,1,5e-3, !* !* R,2,5e-3, !* !* MPTEMP,,,,,,,, MPTEMP,1,0 MPDATA,EX,1,,3.55e9 MPDATA,PRXY,1,,0.365 MPTEMP,,,,,,,, MPTEMP,1,0 MPDATA,EX,2,,70e9 MPDATA,PRXY,2,,0.3 BLC4,0,0,10e-3,140e-3 CYL4,5e-3,35e-3,17.5e-5 CYL4,5e-3,105e-3,17.5e-5 FLST,3,2,5,ORDE,2 FITEM,3,2 FITEM,3,-3 ASBA, 1,P51X CYL4,5e-3,35e-3,17.5e-5 CYL4,5e-3,105e-3,17.5e-5 !* FLST,5,2,5,ORDE,2 FITEM,5,1 FITEM,5,-2 CM,_Y,AREA ASEL, , , ,P51X CM,_Y1,AREA CMSEL,S,_Y !* CMSEL,S,_Y1 AATT, 2, 2, 2, 0, CMSEL,S,_Y CMDELE,_Y CMDELE,_Y1 !* CM,_Y,AREA ASEL, , , , 4 CM,_Y1,AREA CMSEL,S,_Y !* CMSEL,S,_Y1 AATT, 1, 1, 1, 0, CMSEL,S,_Y CMDELE,_Y CMDELE,_Y1 !* SMRT,6 SMRT,1 MSHAPE,1,2D MSHKEY,0 !* CM,_Y,AREA ASEL, , , , 4 CM,_Y1,AREA CHKMSH,'AREA' CMSEL,S,_Y !* AMESH,_Y1 !* CMDELE,_Y CMDELE,_Y1 CMDELE,_Y2 !* FLST,5,2,5,ORDE,2 FITEM,5,1 FITEM,5,-2 CM,_Y,AREA ASEL, , , ,P51X CM,_Y1,AREA CHKMSH,'AREA' CMSEL,S,_Y !* AMESH,_Y1 !* CMDELE,_Y CMDELE,_Y1 CMDELE,_Y2 !* NUMMRG,KP, , , ,LOW NUMMRG,NODE, , , ,LOW NUMMRG,NODE, , , ,LOW FINISH /SOL !* ANTYPE,1 !* BUCOPT,LANB,3,0,0, FLST,2,1,4,ORDE,1 FITEM,2,3 !* /GO DL,P51X, ,UX,0 FLST,2,1,4,ORDE,1 FITEM,2,1 !* /GO DL,P51X, ,ALL,0 FLST,2,1,4,ORDE,1 FITEM,2,3 /GO !* SFL,P51X,PRES,100, /STATUS,SOLU SOLVE FINISH
RE: Help on shape violating errors
If you have "shape violating errors" you must help the software to mesh areas with
esize or Lesize instructions.
Look in Help files.
I wrote this code :
CODE --> apdl
/PREP7 ! Element Type ET,1,PLANE183 KEYOPT,1,1,1 KEYOPT,1,3,3 KEYOPT,1,6,0 R,1,5e-3, ET,2,PLANE183 KEYOPT,2,1,1 KEYOPT,2,3,3 KEYOPT,2,6,0 R,2,5e-3, ! definition materiaux ! mat 1 MP,EX,1,3.55e9 MP,PRXY,1,0.365 ! mat 2 MP,EX,2,70e9 MP,PRXY,2,0.3 !! GEOMETRIE BLC4,0,0,10e-3,140e-3 ! A1 CYL4,5e-3,35e-3,17.5e-5 CYL4,5e-3,105e-3,17.5e-5 ASBA, 1,all ! A1 -> A4 CYL4,5e-3,35e-3,17.5e-5 CYL4,5e-3,105e-3,17.5e-5 AGLUE, ALL ! ----> ___ ! | | ! | | ! | o | A2 ! | | ! |A3 | ! | | ! | o | A1 ! | | ! |___| ! Maillage Asel,s,,,1,2 AATT, 2, 2, 2, 0, ! AATT, MAT, REAL, TYPE, ESYS, SECN allsel,all Asel,s,,,3 AATT, 1, 1, 1, 0, Allsel,all ! ok Lsel,s,,,13,20 Lesize,all,,,6 ALLSEL,ALL Lsel,s,,,1 Lsel,a,,,3 Lesize,all,,,6 ALLSEL,ALL Lsel,s,,,2 Lsel,a,,,4 Lesize,all,,,40 ALLSEL,ALL AMESH,1,2 AMESH,3 FINISH /SOLU ANTYPE,0 ! B.C. DL,1, ,ALL,0 DL,3, ,UX,0 ! LOAD SFL,3,PRES,100, SOLVE FINISH /SOLU ANTYPE,1 BUCOPT,LANB,3,0,0, SOLVE FINISH
