NX 8.0 Post builder force new tool change mill control
I have a mill control and I want to force a tool change/start of operation regardless if the mill control is between two tool paths with the same tool. basically go through the operations start sequences as if its a new tool out putting everything. I'm assuming there's some flags to set to get this done. Right now when I out put the code from the mill control from the post all is good, it then exits this and runs thru the rest of of start sequences but it's out putting as the same tool was used. Any suggestions? to what needs to be set so it sees this tool as a new tool even though its not?
RE: NX 8.0 Post builder force new tool change mill control
Let me know if you need more information.
Frank.
