Need little coding help
The code below plots 'k' along the y-axis and 'theta' along the x-axis.
I would like help on the following, for which I do not know how to write out the code in MATLAB:
1. I want to extract only those 'theta' values corresponding to integer values of 'k'
2. Then, use the above 'theta' values and solve for corresponding 'alpha' values from the equation:
d*sin(alpha) - r*sin(theta-alpha) = 0
3. I would also like to print an array of x and y coordinates corresponding to the above theta values
x = r*cos(theta) and y = r*sin(theta)
n=12;
d = 200;
r = 3200;
dbyr=d/r;
theta=0:0.0001:2*pi;
k=(n/(2*pi))*(theta+dbyr*sin(theta));
plot(theta,k)
Thanks.
RE: Need little coding help
No, not for school assignment.
k does have integer values: 1,2,.......,12. The y-axis of the plot generated shows them.
n=12;
d = 200;
r = 3200;
dbyr=d/r;
plot(theta,k)
Thanks.
OK, I've watsed a minute on this. theta is in integer multiples of 0.0001
k is an integer divided by pi times (x.sin(theta)+theta)
dividing things that aren't pi, by pi, rarely results in integers.
Cheers
Greg Locock
To be precise, there is exactly one integer value in k. You can find it like so:
for j=1:62832
if(round(k(j)) == k(j))
j
end
end
Unsurprisingly, it's the value for when theta is 0. As already stated, everything else gives you an expression with pi, which is never going to be exactly integer.
To suggest "k does have integer values: 1,2,.......,12. The y-axis of the plot generated shows them." is wrong - the plot shows a continuous line. The values of k are discrete, and are never exactly integer (except at the origin). If you want values that are "close enough" to integers, you need to use numerical methods. Time to rethink the problem you're trying to solve. Which is?
IRStuff, the input is never pi, 2*pi or 3*pi. The input is "0:0.0001:2*pi;". So 0 is in but the closest to pi you get is 3.1416 and oddly enough, even the last input is not 2*pi (Matlab rounds it to something a bit surprising - I can't remember exactly what).
I agree, if the input were exactly pi, 2*pi or 3*pi, the equation would give a rational result since the sin term goes to zero and the remaining theta term cancels with the pi on the denominator.
The OP is wandering aimlessly. Look at what he says he wants:
"I want to extract only those 'theta' values corresponding to integer values of 'k' " The fact that he can't even figure out his own Matlab code suggests that his vector for theta is arbitrarily constructed.
TTFN
The OP's question is illogical and makes no sense.
peace
Fe (IronX32)
