Change points number in datum curve created from equation
I work with Creo 2.0
I created a sinusoidal function as a datum - Curve from equation.
Problem is my curve is plenty of irregularities. I work in small dimensions (20*5*5mm).
Is it possible to change the number of points in relation editor where I write the value of my equation?
Maybe it's an other problem...
Thank you for your Help.
PS: Sorry, I can't share the file, It's a confidential product for medical use.
