In-situ machining of heat exchanger pass partition
I am searching for a machine which can do onsite machining of round flange faces as well as pass partition slots of heat exchangers. Are there any such machines available which can do both the jobs?
RE: In-situ machining of heat exchanger pass partition
Is there a reason the channel cannot be taken to a location with fixed equipment to machine that surface? A picture might yield positive results as well.
There are too many unknowns here, and I would want the services of an experienced team.
Some people that perform this on-site( or in situ, if you prefer) work include:
www.onsitemachining.com
www.tritool.com
www.furmanite.com
There are many things that can go wrong at a crucial time. I want people who have done this before...
