How to change the Dimension Text 's Font Size and Name through macro
Could some body let me know how to change the drawing dimension text font size and name.
Thanks in advance,
Maddy
RE: How to change the Dimension Text 's Font Size and Name through macro
Hi
CODE --> CATScript
' Purpose: Macro will change all text greater then 2 into 10 in an active CATIA drawing
' Usage:   1 - A CATDrawing must be active with some dimensions on it
'          2 - Run macro
' Author: ferdo (Disclaimer: You use this code at your own risk)
Sub CATMain()
Set drawingDocument1 = CATIA.ActiveDocument
Set Sheets = drawingDocument1.Sheets
Set activeSheet = Sheets.ActiveSheet
Set views = activeSheet.Views
For i=1 to views.Count
if i <> 2 then
Set view = views.Item(i)
Set texts = view.Texts
For j=1 to texts.Count
Set text = texts.Item(j)
text.SetFontSize 0,0,10.0  'change all text greater then 2 into 10
Next
End if
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Or even better
CODE --> CATScript
' Purpose: Macro will change text in an active CATIA drawing according to your inputs
'          2 - Run macro
Sub CATMain()
Dim myFontSize As Double
myFontSize = "10"
myFontSize = InputBox ("Please enter a font size.", "Enter Font Size", myFontSize)
Dim myFontName As Double
myFontName = "Courier"
myFontName = InputBox ("Please enter a font name.", "Enter Font Name", myFontName)
if i <> 2 then
text.SetFontSize 0,0,myFontSize
text.SetFontName 0,0, "myFontName"
Next
End if
Next
End Sub
Fernando
I'll try to loop through as you said above.
Still one doubt and thought to get the same clarified.
Do the text in dimension should be considered as a text and accessed separately?
I tried to do this but didn't succeeded.
For dc = 1 To oDims.Count ' Dimension loop
Set oMyDimension = oDims.Item(dc)
Set oDimText = oMyDimension.GetValue
oDimText.SetFontName 0, 0, "Courrier 10 BT"
oDimText.SetFontSize 0, 0, 10
Next
Maddy
Tried to display all the text.
But while doing so i'm not getting any dimension text displayed at all.
You mean you want something like this?
CODE --> CATScript
Sub CATMain()
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "CATDrwSearch.DrwDimension,all"
For i=1 to selection1.count
	Set Dimension = selection1.Item(i).Value
	MsgBox Dimension.GetValue.Value
Next
End Sub
Fernando
Yes,
Exactly, That's what i want to change the height and name.
Hi Guys,
Could you please help me on this.
Maddy
I'm afraid there is no solution for what you want (sorry for misunderstanding in the beginning of the thread). If you will put the code from last CATScript in catvba and use the "watch" for Dimension, you will see there is no reference for FontName or FontSize.
Many things are not exposed in drafting workbench for common automation...and I'm afraid this is one of them.
Fernando
