welding procedure for a276 s41500 material
What welding consumables can i used in welding and repair of a276 s41500 for pump shaft and i need repair procedure.defect of shaft is out of roundness.we want increase thickness of shaft by welding before machining.
RE: welding procedure for a276 s41500 material
http://www.sfsa.org/sfsa/pubs/hbk/s7.pdf
