API 682 Warm up procedures
What is the recommended degrees F per hour pump warm up, per API 682?
RE: API 682 Warm up procedures
50 degrees F per hour (this seems very conservative)
50 degrees F per 1/2 hour
I've also seen notes that state the pump's temperature must be within 50 or 100 degrees F of the actual pumping liquid before starting the pump.
Hope that helps,
Thank you
Johnny Pellin
