How do I size a S Shape monorail beam to hang a 1 ton trolly on?
I want to install a simple straight monorail over several large valves to use a trolly & 1 ton chainfall for maintenance work. I would like to size the beam and do the design myself but I am at a loss for where to find the references I need to begin the design. Can you help me or point me in the right direction?
RE: How do I size a S Shape monorail beam to hang a 1 ton trolly on?
Steel monorail crane construction can be quite challenging even for small jobs due to the moving nature of the load and the interaction with the existing structure. I advise you seek the advice of a structural engineer in your area for guidance if you are not experienced in steel design. I would really hate to hear about an OSHA violation or injury due to a falling 2,000 lb load.
Thank you for the reference information and advice. I am requisitioning the manuals and I plan to hire a Structural Engineer to review any design I come up with before we go to construction.
You were very helpful, thanks again.
Vincent63
