Feature of Size (FOS)
As I understand it, a FOS must satisfy all of the following:
  • Contains opposing elements or surfaces (regular or irregular shapes).
  • Can be used to establish an axis, median plane, or a center point.
  • Is associated with a size dimension.
Then you hear about the "Caliper Rule", where you should be able to measure or pick-up the feature with a pair of calipers (or 2 fingers).
My question is, what if, for example, you have a lens cell (for opto-mechanical design) with 3 tangential flexures 120 degrees apart about a common axis, and on those flexures you have raised pads which interface with the glass lens. These pad surfaces are arced and between the 3 of them they essentially form a diameter. Doe this constitute as a FOS (internal)?
I say yes. Even though the elements or surfaces are not "opposed" and you could not measure or pick-up the feature with a pair of calipers, you could measure or pick-up the feature with an expanding pin. Would this fall into the "irregular FOS" category?
Sean
RE: Feature of Size (FOS)
If I picture this correctly, my answer is yes - this is internal irregular FOS.
Season,
Yes thank you for that link. That's pretty much it...
Sean
