Very different result between 2D and axisymetric
I'm working on an impact problem with a sphere hitting a deformable substrate. I did it first with and axisymetric model and I got results that look good/expected. No I want to add complexity that rules out an axisymetric approach, so I tried to recreate what I have so far in 2D.
The trouble is, the deformation that I'm getting in 2D is much different than in axisymetric and I don't know why. The spherical particle is deforming less and the substrate is deforming more. I used the same temperatures, velocity, and material definitions.
Anybody run into this before? Or does a possible source of this error spring to mind? I'd really appreciate any advice.
Thanks!
Thanks!
RE: Very different result between 2D and axisymetric
Is there a way to make it assume that a circle in 2D is a sphere and not a cylinder? I guess it's probably just in the part creation options, I should be able to figure it out but I wont have access to ABAQUS until Monday.
Thanks!
