Advanced Simulation - missing results
I have a small problem.
I am trying to simulate shaft in nx 8. I've done everything create mesh, all loads needed, constraints, even in Solution 1 I just for sure run "Model setup check" and run "Solve" everything went well but When I tried to run Results a warning window showed that "Result file is in wrong format". I check everything and really don't know what is wrong.
thanks for help.
thanks for help.
RE: Advanced Simulation - missing results
I have nx 8.
I've forgotten
