Reference Sets in NX 7.5
Hi all,
I am using the below journal to create a new reference set "S" and move all the assembly components to that reference set. And it will show the an error popup like reference set exists, if there is already a reference set 's'. But, I am facing a problem with this journal. If i execute this journal multiple times it was creating duplicate reference set as shown in attachment. Kindly advice me in resolving this issue.
CODE -->
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Create New Reference Set")
        Dim referenceSet1 As ReferenceSet
        referenceSet1 = workPart.CreateReferenceSet()
        referenceSet1.SetName("S")
        'add all components (existing and future)
        referenceSet1.SetAddComponentsAutomatically(True, True)
        'create list variable for solid bodies
        Dim mySolids As List(Of Body) = New List(Of Body)
        'workPart.Bodies collection contains both solid and sheet bodies
        'filter out solid bodies and add them to the list
        For Each solid As Body In workPart.Bodies
            If solid.IsSolidBody Then
                mySolids.Add(solid)
            End If
        Next
        'add solid bodies to reference set
        referenceSet1.AddObjectsToReferenceSet(mySolids.ToArray)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
Thanks & Regards,
Sam
RE: Reference Sets in NX 7.5
Check to see if the reference set exists before creating a new one with the same name.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
		Const newRefSetName As String = "S"
		Dim found as Boolean = False
		Dim myRefSet as ReferenceSet
		'check to see if reference set already exists
		For Each myRefSet In workPart.GetAllReferenceSets()
            If myRefSet.Name.ToUpper() = newRefSetName Then
				found = True
				Exit For
            End If
        Next
		If Not found Then
			'create new reference set
			referenceSet1.SetName(newRefSetName)
		Else
			'use the existing reference set
			referenceSet1 = myRefSet
		End If
                mySolids.Add(solid)
            End If
        Next
    End Sub
    End Function
End Module
www.nxjournaling.com
The above code is working fine..(Thanks for that)
I like to add another points to this code..
1. I need a notification window stating "REFERENCE SET S ALREADY EXISTS" (If already reference set s is created)
2. In the same way I need the notification window stating "REFERENCE SET S CREATED". (When this journal creating reference set s)
Thanks & Regards,
Sam
