Need help wiring up an old Westinghouse Motor
I have a Westinghouse Motor
1/3 HP 800 RPM 230V single phase motor Code R NEMA
Model 312P532
Serial BL73
Type FT
56Y Frame
60 #2
Thermally Protected type C
Has a starter capacitor and a run capacitor. The motor is old, around 1970ish.
When I got it there were 3 leads coming to the motor. All connected to the motor lead terminal block. Blue Black White.
Need help in wiring it up correctly.
Model 312P532
Serial BL73
Type FT
56Y Frame
60 #2
RE: Need help wiring up an old Westinghouse Motor
"Will work for (the memory of) salami"
Thanks again!
