How to get bodies and faces in a Fem model ?
Hi every one , i have a small problem.
i'm trying to get faces to change color depending on the face type , but this in not the probleme i managed to do that but only when i'm working in modeling module.
i need to do the same for Advanced simulation (.fem parts) module.
i tried to change work to basework in this code but it still works only in the modeling module (ie .prt).
" Dim workPart As object = s.Parts.baseWork
Dim bodies As BodyCollection = workPart.Bodies
For Each b As Body In bodies
For Each f As Face In b.GetFaces "
Thank you.
Thank you.
RE: How to get bodies and faces in a Fem model ?
www.nxjournaling.com
can you explain please how can i get a reference to the component and make some changes (not only changing colors what i have in mind but also doing a mesh and create coordinate systems dependent on the suface type , but this is not the problem , my problem is i cant get faces in fem part) .
i managed to do that by using a selectobjects method , but i want to create a journal that would do that automatically without prompting the user to select anything.
thanks.
When you are working on your FEM part, are you working on the model itself, or an occurrence (a component)?
I hope this will clarify the probleme.
thanks again.
