Reverse direction of line
You can reverse the direction of non-associative curve? Or quick replace start-end point.
NX 8.5.1.3
RE: Reverse direction of line
I recently was thinking the same thing.
I do not think there is a way to reverse the curve after it has been placed down.
The only way I know of is to reselect your points. You need to select a point out in space for the start point then select switch to end point and select the old start point then switch back to start point and select the old end point.
Here is a quick journal version (for NX8 and above) of moudy1's method. I have not tested it on associative lines or sketch lines, those may cause problems. Use at your own risk...
CODE
'May 2, 2013
'reverse direction of non-associative line
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
		Dim workPart As Part = theSession.Parts.Work
        Dim myLine As Line
        If SelectALine("Select a line", myLine) = Selection.Response.Cancel Then
            Exit Sub
        End If
        myLine.SetEndpoints(myLine.EndPoint, myLine.StartPoint)
    End Sub
    Function SelectALine(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a line"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_line_type
            .Subtype = UFConstants.UF_line_normal_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
Thank you, working ok.
NX 8.5.1.3
