Testing Above Grade Isolating Flange
We have in our company about 3 KM length pipeline with cathodic protection. The line take about 3 A Current. The contactor gave the reason for this high current is draining of the current from isolation flange. We tried ON/OFF survey and the results of it shown the difference of 10 mV between the ON and OFF in station side (after isolation flange), , is this indication evidence of failure in the flange ? any one has NACE standard for this point
Thanks in advance
Thanks in advance
RE: Testing Above Grade Isolating Flange
If not have you tried measuring the resistance across the flange? A well coated pipeline should have a significant resistance.
The fact that there is any change in potential on the station side (where was this referenced from ?) gives rise to some concern, but could be due to other reasons.
Isolating flanges are notorious for failure either of the gasket or the insulating washers and sleeves for the bolts. Can you post a photo or give some details, size, flange rating etc.
Also check if there is any other contact between the pipeline and any support or metallic item connected to ground before the flange.
Don't know what size/age/conditions there are at your line. Sandy/rocky soil, poor coating, larger diameter pipeline will require more current. If the line is new I would say this is too much current.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
