Non destructive examination of the inside of a nozzle
Hi
I have a nozzle that has a converging section, a diverging section, followed by another converging section at the nozzle tip. The nozzle is about 0.5'' inside diameter at the converging sections. The nozzle is about 3.5' long and has a constant outside diameter of 1''. It is made of steel, although I am not sure what type (classified). The nozzle tip has eroded significantly. I need to determine how the geometry of the inside of this nozzle has changed. I would really prefer not to cut it open, as it is needed for tests to determine how the erosion has impacted the spray quality. As well, I would use a mold, but it may not give me all the details of the internal geometry that I need, and it is hard to pull out of the nozzle and keep intact once it has set.
Are there any non-destructive examination tests that I could use to determine what the nozzle looks like on the inside so that I can get a good visual of where the erosion inside the nozzle has occurred? Thanks!
Nick
Nick
RE: Non destructive examination of the inside of a nozzle
I have found digital RT provides excellent sensitivity to density changes related to material loss. The remote field eddy current testing can be done from the outside surface of the nozzle.
I have considered a mold. I am going to try that, but I need the mold to fit through the tip of the nozzle, which is 0.5''. The widest part of the nozzle is about 0.88''. Therefore I am not sure that the mold will stay intact as I try to pull it out, and I am afraid the details of the erosion will be lost.
Thanks for the replies.
