Differences between water pumps
Dear all,
I'm translating a text on pumps into English and I need to know whether "chain pumps", "chain and washer pumps" and "paternoster pumps" refer exactly to the same thing, only with different names.
Thank you very much for your help.
Patricia
Patricia
RE: Differences between water pumps
So how about having a look yourself, I'll give you a clue, look for paternoster pumps.
I do agree with artisi though and perhaps google or google images would have given you the answer equally as well....
Artisi, thanks to you too for taking the time to reply. I should probably have made it clear that I'd already checked Google (who'd have thought it?), Google Images and many other sources before posting my question. Translators generally use forums when looking for expert advice after their own research has failed to provide a satisfactory answer. I can assure you that it's by no means a lazy option. Apologies, though, if my post offended your sensibilities in any way.
OFF TOPIC:
I might have given the same answer as Artisi, since we get so many questions that have not been researched by the poster. Thank you for pointing out that you hit the Google first.
I'm not a pump guy, but since you are a technical translator, I wanted to point you to this forum on eng-tips:
Translation Assistance for Engineers
You certainly don't need English assistance, and the technical forums are appropriate for questions you may have. The translation assistance group is for those who need a hand. It is a relatively new place, so it's not very active yet. But we can occasionally use some help there (hint)
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Thanks anyway for the tip
http://www.fao.org/docrep/010/ah810e/AH810E00.htm
see 3.6.7 for a good description of what you are seeking.
