Reinforce transparent plastic
I have recently installed a machine for leak testing
car radiators.  The machine works by lowering the radiator
into a tank of water and blowing compressed air into it.
If bubbles are seen, the core is a "leaker" and has to be repaired.  To hold the core in situ whilst pressure is applied, a bar at either side clamps the core between both header plates.  These bars are stainless steel and therefore cannot be seen through!  Subsequently if a leak occurs where these bars mask, the leak cannot be located accurately.  I intend to replace these bars with a material that is transparent, but durable.  I would be grateful for any suggestions.
Paul
RE: Reinforce transparent plastic
Your options include:
1) glass - obviously has a toughness problem, but you could use a tempered glass or a more exotic type like Pyrex
2) thermoplastics - polycarbonate and acrylic are two varieties, although they may suffer from creep and environmental degradation.
3) thermosets - epoxies and polyesters are two varieties, they have improved creep and environmental resistance compared to thermoplastics, but reduced toughness.
Lexan is another option.  It's definitely durable (it's used as bullet-proof glass).
Haf
Haf,
Lexan is the trademarked name for polycarbonate manufactured by GE Plastics.
