Stress analysis of laminated composite cantilever beam
I have a doubt regarding the stress analysis of laminated composite cantilever beam. How do I carry out the stress calculations of a cantilever beam with a point load at the end of 10N?say for example I have a beam of length 1000 mm, width of 20 mm of 6 plies of 1 mm each so thickness will be 6 mm. I have used carbon/epoxy (0/45/90)s layup and material properties are E1=126000 Mpa, E2=11000 Mpa. I dont know how to calculate such problems without FEA. I want to know how to solve such problems using a calculator.
Please help
Bharat
Please help
Bharat
RE: Stress analysis of laminated composite cantilever beam
Blakmax
http://www.matter.org.uk/matscicdrom/manual/co.htm...
