Overiding Rule #1
3
Overiding Rule #1
Overiding Rule #1
Why was the ability to override Rule #1, with straighness on a FOS dimension, created in the first place?
I'm curious to hear other people's opinions.
Sean
RE: Overiding Rule #1
Basically, in practice, for too many cases "the envelope principle" is unrealistic.
Frank
Since Rule #1 is a catch-all default that controls form unless otherwise specified, then having a straightness tolerance on a feature of size counts as "otherwise specified."
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
As I understand it, the only time rule #1 is overridden is by the following:
1) Special note stating such override
2) Stock material is not applicable
3) Straightness control on a FOS dimension
So in terms of geometric characters, there is only the one way. That's why it's curious to me. But after thinking more on it, I tend agree with fsincox and his comment about an unrealistic envelope. In a lot, if not most cases, straightness control of a FOS (axis or median plane) would be for long parts. By virtue of the indirect form control of Rule #1, the envelope for a part that is long can be unrealistic if the size tolerance is relatively small.
I think this logic makes sense.
Sean
If you followed my link, you would find 4) When LMS/LMB is applied.
To Sean's list, another would be non-rigid parts: Rule #1 doesn't apply for non-rigid parts subject to free-state variation.
John-Paul Belanger
Yes that's right, non-rigid parts subject to free-state, as shown in CheckerHater's link, is another case...
I was really focusing on geometric characters, more than anything, and the fact that there is only one that applies and even that has to be specifically relative to a FOS dimension. Just a nice mental note, that no other geometric characters override Rule #1.
Sean
Quote (SpaciouS)
True as long as you are working to '94 version of Y14.5. In Y14.5-2009 there are two additional ways to override rule #1:
1) Independency modifier (I in a circle) - which is nice and short substitute of text note.
2) Flatness control on a FOS dimension - controlling derived median plane of a non-cylindrical FOS.
Rule #1 does not apply to an irregular FOS, it only apply to regular FOS.
Season
Ahh okay, thanks for the tip pmarc, I was not aware of this.
I will review the 2009 standard on this topic!
Sean
