Macro to change partname and instance name
Hi Friends,
I have written a code for renaming all part's name and instance inside a product.
For eg. if it is part1(part1.1), part2(part2.2)
it will change the number and instance to say vik1(vik1.1),vik2(vik2.2)
I have just started with automation, need suggestion, wht other things i can add or change to make it better.
PFB the code.
Sub CATMain()
Dim iCount As Integer
Dim sPoint As String
sPoint = "."
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim products1 As Products
Set products1 = product1.Products
For iCount = 1 To products1.Count
products1.Item(iCount).PartNumber = "vikas" & iCount
products1.Item(iCount).Name = products1.Item(iCount).PartNumber & sPoint & iCount
Next iCount
End Sub
All suggestion and comments are welcome.
Thanks.
RE: Macro to change partname and instance name
It depends on Products structure, if its flat, this macro fulfill Your needs, but if it's more complex, and yours company rules allows same instance names inside two different products, more suitable will be Recursive approach (I and others have posted different approaches for recursive product's tree scan)
Also You should consider to rename only documents that are Parts, not Products (then You need to create other variable for instance number)
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
