Workbench, difference of two results computation
Is it possible to compute the difference beween 2 results in ANSYS workbench? for example, from simulation1 results and simulation2 results we somehow subtract the results to get the error?
Thanks alot!!
Jessi M.
RE: Workbench, difference of two results computation
I will reply to myself because i found the solution!
There is a Result system in ANSYS workbench, it can compare the results of 2 simulations or more. After combing all results run the simulation and export data.
Jessi M.
