Essential textbooks for Structural Engineering
Hi guys,
So i'm just fresh graduate working in structural engineering.
Was just wondering if you guys could recommend the best text books covering any structural design topic which reference the AS/NZ standards?
I already know of the steel designers handbook, and reinforced concrete basics.
Was hoping to find more gems like this which provide detailed guidance into the stuff they never really taught at uni.
Cheers
Cheers
RE: Essential textbooks for Structural Engineering
"Concrete structures" Warner et al
"Design of Prestressed Concrete" Gilbert
“Reinforced concrete mechanics” MacGregor,
"PCI design Handbook" PCI,
"Precast concrete Handbook" NPCAA,
"Reinforced concrete elements" Beletich,
"Reinforcement detailing handbook" CIA,
"Standard method of detailing" Istruct,
"Design of tilt-up concrete wall panels" CIA,
“Reinforced concrete”- economic guide R/C, P/T ect.
“Structural engineering pocket book”- Fiona Cobb
Steel:
"Steel designer manual" The steel construction institute,
“Design of Portal Frame Buildings” ASI
“Rigid and simple connection series” ASI
"Design Guide - Portal Frames Steel Sheds and Garages" ASI
"Economical Structural Steelwork" & ASI Journal
"Structural steel semi-rigid connections" Faella,
“semi-rigid” base plate design notes, AISC design guides.
Foundation: "PRINCIPLES OF FOUNDATION ENGINEERING" Das
Materials: Roarke
Finite element: "finite element design of concrete structures" Rombach
Costing: "commercial and industrial building cost guide" Cordell
Vibration: "Design guide 14" AISC, HIVOSS for bridges
Wind: "wind loading of structures" John Holmes
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
This is really great!
AS4100 Supplement 1 - Commentary
This appears to have been broken into sections, though as a start:
http://steel.org.au/bookshop/handbook-1-design-of-...
and
http://steel.org.au/bookshop/design-capacity-table...
http://steel.org.au/bookshop/design-of-structural-...
Lyle
http://www.eabooks.com.au/epages/eab.sf/?ObjectPat...
Lyle
