ABS plastic case and screws vibration issue!
Hello again!
I am trying to hold two ABS plastic cases together with a M2 mild or stainless steel (pan head) screws. The problem here is vibrations during usage, though they are not very high I don't want loose back case during normal operations by customers.
I thought of using Thread locker loctite and they don't work on plastic.
I want them to be easily removed during repairs but prevent vibrations, so I thought of using spring washers between a flat and screw or a earth washer which probably digs in the plastic.
Or even i could just paint the screw heads which could potentially prevent vibrations.
Do you think any of the above might work or any other better suggestions please share.
Any help is appreciated.
RE: ABS plastic case and screws vibration issue!
SceneryDriver
Major design change - I am trying to hold an aluminium and abs part together.
I am seriously considering through bolt and nylock nut but space is a problem.
I don't know how good it will be during vibrations if i use a taptite screw through al.
http://www.ejot.com/ejot.de/Product_Range--4800.ht...
http://www.sfsintec.biz/internet/sfsinten.nsf/Page...
http://www.emhartamericas.com/brands/spiralock/tec...
