throttle body
throttle body
i have being working with diesel generator for over ten year and only yesterday on a truck i came across a throttle body on a diesel engine and found it strange cause i never seen this before, so can you guys please explain its purpose.
RE: throttle body
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
RE: throttle body
What you probably have is a safety device called a shutoff. When you pull the cable, a blade or butterfly snaps shut, completely closing off the the Diesel's air supply.
Cutting off the air suppply is the only way to save a runaway Diesel from destroying itself. A runaway doesn't happen often, but it does happen. Diesels normally run with the air supply wide open, and speed is controlled by metering the amount of fuel oil that's injected. Unfortunately, Diesels will also happily run on their own lube oil, e.g. when a piston ring fails. Shutting off the fuel supply won't stop the engine if it's running on lube oil.
I personally think shutoffs should be required on all Diesels, but most manufacturers would prefer to saddle the owner with the cost of a runaway, and pretend it never happens to their engines.
Mike Halloran
Pembroke Pines, FL, USA
RE: throttle body
RE: throttle body
RE: throttle body
Bill
RE: throttle body
A complete description of the question, is usually worth an answer.
Year, make, model, # of cylinders, displacement, location (who knows what it could be if it is in California.)
RE: throttle body
the lever that control the amount of air also control the amount of fuel at the same time: If it's a mechanical rack engine, then it very likely does not have any "modern" emissions control equipment on it
Is this by chance a naturally-aspirated prechamber diesel engine (with indirect injection)?
RE: throttle body
RE: throttle body
Bill
