Macro to select node in tree then Activate for editing
We have a fairly consistent tree that is generated by another process. What I would like to do is create a macro that will select a node that is two levels down, expand it, then activate it for editing.
I've tried a few things, but nothing seems to activate the node (like a double-click would). I do have most of it working in catvba. Anybody have some catvba that would help activate the node?
RE: Macro to select node in tree then Activate for editing
Is it supposed to be the final result of Your macro OR activation is necessary to start another procedure (e.g constraining child of active component? ?
Solutions:
If case
1. - There is no need to activate object by double-click on it (as node on tree)
2. - You can select desired object (through macro) and start appropriate workbench by CATIA.StartWorkbench("Part Design") command
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
You have to create external Shell script that activate node (object to activate must be selected) and save it as vbs file
in this case filename is: "D:\ActivateNode.vbs"
CODE -->
Set WshShell = WScript.CreateObject("WScript.Shell") WScript.sleep 200 WshShell.SendKeys "c:FrmActivate" + "{ENTER}", TrueIn Yours Catia macro:
CODE -->
We have some users that want to skip the double-click because each node under the VSYS_CHASSIS node represents a bill of material that needs to be positioned along a chassis frame rail. Expanding and activating the node allows them to save wear-and-tear on their fingers.
I would go with first solution, using SendKeys is a little bit tricky.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Why do you say Sendkeys is tricky?
When I said first solution was thinking of something like this (lukaszsz gives you just some guides, no one has time enough to give a complete solution):
CODE --> CATScript
Language="VBSCRIPT" Sub CATMain() Dim documents1 As Documents Set documents1 = CATIA.Documents Dim partDocument1 As Document Set partDocument1 = documents1.Item("VSYS_CHASSIS.CATPart") Dim part1 As Part Set part1 = partDocument1.Part Dim selectPart Set selectPart = CATIA.ActiveDocument.Selection Dim editPart Set editPart = partDocument1 selectPart.Add(partDocument1.Part) CATIA.StartWorkbench("PrtCfg") selectPart.Clear() editPart.Activate() End SubSendKeys is tricky because you need to find how many seconds you should delay the execution (or maybe is not necessary), maybe you have another process on your computer which can interfere with SendKeys command, a.s.o.
Fernando
