NSF-61 certified expansion joint or hose for tank nozzle
Hello folks.
I have an AWWA potable water tank on a gravel pad. Design consolidated settlement is in excess of 1.5 inches. The piping is not particularly flexible, so I need an expansion joint between the tank and the closest pipe support. Can anyone suggest suppliers from whom I might source NSF-61 certified hose / joint for potable water (drinking water) service?
RE: NSF-61 certified expansion joint or hose for tank nozzle
What size piping is involved?
rconner,
What a bonehead move on my part for not mentioning that. I am sorry for that, because that is at the centre of my problem.
Sizes involved are 2" NPS, 3" NPS, 4" NPS, 6" NPS, 8" NPS and 10" NPS, all flanged 150# RF x 150# RF, proposed 304L SS.
The real issue is the combination of poor foundation design and even worse piping design, exacerbated by the fact that it is a glass-fused-to-steel tank with allowable nozzle loads of zero.
Metrasphere is available in Hypalon which is an NSF product
but they may have testing on the standard product line as well
Hydrae
I could, of course, just read the FlexiCraft ad at the top of the screen.
In applications such as this, the piping is not brought straight out from the tank. Instead, the piping is usually installed with an elbow to turn the piping sideways and then reverse back to another elbow. This piping arrangement adds some flexibility to the piping.
Installing the piping in this manner is probably a better solution than an expansion joint on a straight out piping arrangement.
