Overhead Crane Columns
Wondering if there is any publicaitons or data on when to use seperate crane columns vs attaching crane runway beams to the main building frame columns. I have a 40' tall building with (2) 30 ton cranes with possible expansion. I would gladly do prelim. engineering work on this, however this isn't in our budget and would stray from preliminary plans that were presented.
RE: Overhead Crane Columns
http://www.eng-tips.com/viewthread.cfm?qid=340535
Now, you don't say whether or not you plan to attach to the existing columns using brackets, or if your are trying to fabricate a stepped column or if you are trying tor frame the system completely independent from the structure. I have never done a crane that large, I would definitely not use brackets, I would probably use a separate crane column.
Some good information can be found in AISC DG 7.
Hope this helps.
DaveAtkins
http://www.cisc-icca.ca/files/publications/techpub...
3. Brackets should not be used to support crane beams with unfactored reaction greater than about 250kN.
Has anyone else seen this stated elsewhere. I would like to see it in a more specific tone.
After the design of my last facility (a 15-ton crane with a 58 foot bridge), I would place my rule of thumb for bracketed crane columns at around 15-tons. Anything over 15-tons I would use a separate column system. This seems to fall in line with DaveAtkins. I have talked to others in the metal building industry and I have been told that they will frequently use stepped columns for large cranes. I have also visited a few fabricators, one of note had 2 5-ton cranes on the same line located on a separate column system braced back to the main building columns.
