Clear Span as specified in SDI
When it says clear span on SDI (Steel Deck Institute), does it mean from center line (web to web) or flange tip to flange tip.
Thanks in advance.
Thanks in advance.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Clear Span as specified in SDI
But in my project there are only three of them, so my question again will be if we can calculate the length from flange tip to flange tip then can I use that as clear span or I still have to use from center line of web to web as clear span
BA
