Magnetorestrictive Level Measurement
Dear Sirs
in a P&ID for a Gear Pump, is present this note "magnetorestrictive Level Measurement"..
The instrumentation should be supplied by pump vendor or this is an instrumentation department problem??
RE: Magnetorestrictive Level Measurement
Depends - is the pump vendor on the hook for the fluid reservoir and its level sensor?
