NX Materials XML library
Does anybody know any tricks or tips on how to ensure that the XML format of the NX Materials library is correct.
Ours is 1000's of lines long, so not practical to visually check.
I dont need to checkthe material data itself, but ensure the schema of the file has not been corrupted.
Cheers,
NXj
RE: NX Materials XML library
Does anyone know how to output in xml format a BOM. Need the indented assembly structure and attributes output as xml as input to our ERP.
ToolingGuy78
NX 7.5
@nxjockey,
I did the the check in IE internet explorer - open the xml,mtx or....
@ ToolingGuy your ERP expert should do it with your material.xml, some transfromations...
