Python code
Python code
Hi guys,
Does anyone have Python code for calculating vibration magnitude and phase shift using a PC sound card?
thanks
Mark.
thanks
Mark.
RE: Python code
import audiolab, scipy
x, fs, nbits = audiolab.wavread(filename)
X = scipy.fft(x)
If you want the magnitude response:
import pylab
Xdb = 20*scipy.log10(scipy.absolute(X))
f = scipy.linspace(0, fs, len(Xdb))
pylab.plot(f, Xdb)
pylab.show()
which all seems jolly relevant to me
Cheers
Greg Locock
RE: Python code
http://vibrationdata.wordpress.com/category/python...
http://vibrationdata.com/python-wiki/index.php?tit...
Good Luck,
Jim
Jim Kinney
Kennedy Space Center, FL
RE: Python code
RE: Python code
For example, real time fast slew rate antinoise systems use time signal filtering, they don't bother with frequency domain.
Cheers
Greg Locock
RE: Python code
managed to get a simple program to detect phase shift using zero crossings. however I just discovered there is another method called the "wattmeter method". It is more robust from what I understand. Does anyone know how it works and how I could apply it to software code?
thanks
mark.
