Cells without dependent cells
Is there any way within Excel, that on a given worksheet, it will show which cells (that have a formula) have no dependent cells?
RE: Cells without dependent cells
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
TTFN
http://www.ozgrid.com/forum/showthread.php?t=73194
but note that I have not tried to test this code.
I found this by using a site I think I discovered through Eng-Tips:
http://www.jpsoftwaretech.com/vba-search-engine/
Note also that if it is used ON THE SHEET then supplying a range as the argument CREATES a dependent cell or cells.
CODE -->
