Mutisection surface with guide curve support
Hello everybody
It is simple to create a multisections surface with a continuity on section support. But I don't know how to create one with guide support. Can you please guide me which conditions I must take into account?
RE: Mutisection surface with guide curve support
Hello AFROUZ3,
It is not very simple to explain... but you can find the methodology for Multi-sections Surfaces here.
Also, these YouTube videos might be of help:
Hope this helps,
Best of luck!
CATIA v5 — user & trainer
ANSYS — user (beginner)
TibiX, Thank you. I am familiar enough to use multisections surface. The only thing I can't imagine is this:
Similarly, you can impose a tangency onto each guide, by selection of a surface or a plane (the direction is tangent to the plane's normal). In this case, the sections must also be tangent to the surface.
It would be a nice help if someone could attach an example of this function?
