Vibration units convertion
Hello Everyone!
I'm trying to get a signal from my accelerometer sensor, which its sensivity is 100mV/g, and convert it to velocity (mm/s).
Does anyone knows how do it?
Best regards,
Adriano
Best regards,
Adriano
RE: Vibration units convertion
a=dv/dt
http://www.eng-tips.com/viewthread.cfm?qid=1743
So, the right units are 100 mV=9810 mm/s/s, or 1V=98100 mm/s/s. You need to set that on a knob or type it into table, depending on your instrumentation.
Filtering I won't discuss in a little text box.
Integrating in the time domain can be done with an integrating amp, or digitally.
Cheers
Greg Locock
