Dimension has arrows only - no values
Hi all, Newby to solid edge
When I try to dimension an element, using any of the dimension functions, ie smart dimension et al, I only get the arrows - no values.
What am I doing wrong ?
RE: Dimension has arrows only - no values
You probably have the dimension type set to BLANK.
If it is, when you click place dimension the icon with the "X" on it will appear greyed-out.
Click the icon and select one of the other options.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
