assembley problem
assembley problem
I have made a latch for a bin in assembly but, when I move one part to lift the other it just go straight through it.
When i put mates to it, it will move but stays to it so it wont open any wider can anyone help please.
RE: assembley problem
If I were to guess, I'd say you're not mating things correctly.
Jeff Mirisola
My Blog
When it is shut close the latch should move up when in contact with bracket, so it slides up the front then drop in the catch part.
Then when twisted it can come apart to 45 degrees, what I want it to do is recognize that a solid body its there.
I hope this explains a bit better than before.
Jeff Mirisola
My Blog
Thanks for your help.
If you want to keep the movement, you'll need to use a path mate to do so.
Jeff Mirisola
My Blog
