Apparent Conflict between Different Codes
I am looking at an existing 40' tall steel lattice tower mounted on an existing building.
The building design falls under the IBC, but the tower under ANSI TIA 222-G, and the IBC in section 3108.1 specifically states that the loadings specific in TIA 222-G shall govern for the Tower design, not the IBC.
That's all well and good, but the building seeks the Kzt factor for wind and ASCE 7 gives the equation to calculate it to apply to the building forces, and TIA 222-G magnifies the wind loads by a "topographic Category", applying unknown factors to the wind pressures per this category that are not quantified externally in the output. I have no way of determining what value of the factor was used... other than calling TNX Tower, which I will.
My problem is that the jurisdiction wants me to apply the Kzt to the tower in spite of the code exclusion, but I can see the logic of their position too in that the tower is sitting on the building, not the ground. From Google Earth, I calculate 1.19, and they calculate 1.38, which may be a local cover-it-all factor, not site specific. I see no way of applying the Kzt factor exactly within the confines of program input other than the topo factor, which will not give the actual case, but something far more restrictive, ending up being way too conservative in my opinion.
I guess that I just have to call the reviewer and TNX tower and see what I can work out...
Mike McCann
MMC Engineering
RE: Apparent Conflict between Different Codes
Section 102.1, from the 2006 IBC, requires "the most restrictive"application when
different materials, methods of construction or other requirements are
being considered.
