can i use ASTM A53 pipe 8" sch 80 at 400 C constant temp
I am rebuilding a mixer that´s inside a salt bath inside a reactor. The only material that i have available is the 8 " sch. 80 ASTM A53 Gr. B, I´m worried about graphitizing. It will be working at 400 degrees Celcius constant. It will be used as support for the shaft wich is SS A420.
Please any advice
Please any advice
