ATFP for Pre-Engineered Buildings - UFC 4-010-01
Has anyone had success with requiring the Pre-Engineered Building Manufacturer to design their building for the Blast Requirements of UFC 4-010-01? The building's current conceptual design does not allow for all building components to fall within the Assumed Parameters of Table 2-3 (i.e. main bent frames are spaced outside of the 20-25 feet range given for "Girts" in the Table).
Also, the building wall system will be a "hybrid" system where as brick veneer will be used from FFE to 40" above FFE, with 8" cmu backup. Typical metal panel and wall girt backup system will be provided above the cmu. Does this "hybrid" wall system automatically force us to design the PEB and cmu wall for blast loads, and not consider it Conventional Construction?
Thank you.
Thank you.
RE: ATFP for Pre-Engineered Buildings - UFC 4-010-01
Make sure you even have to meet UFC 4-010-01. If there are 10 or less DoD personnel in the building or the occupancy density is greater than 1pn/430sf, you don't have to.
