Problem in extracting output with Abaqus
Hello to everybody..i work with Abaqus from few time and i have a problem to extract data output from OBD Field Output...if i ask for the results in more than about 300 nodes i get the error message: 'Requested operation will result in creation of a very large number of xyDataObject.Please reduce the number of specified entities using Dysplay Group operation before re-performing this operation'..It happens with all the parameters requested even asking for only one step frame result, and it's strange because if i choose the 'picking from viewport' method to select nodes and i select less than 300 nodes everytime i can extract data results..it looks like a software data limitation..anyone can help me? thanks
Alessandro, Biomedical engineering student
RE: Problem in extracting output with Abaqus
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Therefore, you can generate several report files each one for each region that you want.
Python is not piece of cake, you need to spend some time.
