Radius as a datum
Radius as a datum
Can a radius be a datum?
RE: Radius as a datum
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
Radius shown in fig. 4-29 does not derive an axis.
So what IS datum B on 4-29?
Pmarc -- sure, it constrains the rotational degree of freedom, but if it's not an axis, what does the 28 mm dimension originate from?
Maybe we're getting sidetracked on another academic thing. ImnotfromMars -- can you provide more info about your situation or a sketch?
John-Paul Belanger
John-Paul Belanger
1. Explanation given in para. 4.11.4. Notice that datum axis/center plane interpretation applies only to features-of-size type of datum features [subparas. (d) and (e)]. When it comes to the surfaces, there is no such interpretation, which sounds reasonable to me because of... see point 2.
2. What if surface B was an irregular basic contour (like for example a set of basic radii tangent to each other), so that it would be impossible to clearly identify a center of datum feature simulator B? Would you search for a datum axis or a datum plane in that case? Would this be convenient interpretation at all?
So trying to answer to CH's question -- I am leaning towards saying that THERE IS NO datum B in fig. 4-29 - at least this is how I understand the letter of the standard. There is just datum feature B that is serving (through its datum feature simulator) as a rotational constraint for 2 planes derived from datum axis A, but that is all.
Does it sound reasonable at all or should I prepare for attack?
Well, you know I don't likre it!
Turn the page: There is no datum B in Fig. 4-30 either? But most of us would say that there is a datum B (a plane) for that part.
John-Paul Belanger
From Para. 3.4.3 Y14.5-2009:
“Where more than one datum is required, the datum feature reference letters are entered in separate compartments in the desired order of precedence”
As long as letter B has its own “separate compartment”, there is a datum B – that’s the letter of the standard.
I admit that the radius in Fig. 4-29 is not a feature of size. But there has to be a datum (else why have a datum feature?) and that datum must conform to the definition of a "point, axis, line, plane, or combination thereof" (para. 1.3.13).
John-Paul Belanger
To me surface that has axis and the radius is mathematically defined enough.
Standard recommends using coordinate system for “disfigured” features.
So if your drawing (or better yet CAD data) shows origin with X, Y, and Z sticking out; what could be easier than derive point, axes and planes from that?
See Figure 4-28 and notice that the datum is a plane, although offset from the part by the 44.4 dim. (Or is this a case where you would say that the standard doesn't use the word "datum" in its explanation of that graphic?)
John-Paul Belanger
Frank
Interesting discussion. Very interesting.
I agree that examples such as this expose the limitations in Y14.5's current datum reference frame theory. The plane/line/point datum concept makes things certain things easier to understand for very simple cases, but breaks down very quickly for more complex cases.
Y14.5-2009 provides a table in Figure 4-3 showing simulators, datums, and DOF constraint for various types of datum feature geometry. But these only apply to primary datum features. There is no explanation of how datums work for lower precedence datum features, where certain DOF's have already been constrained. Hence the confusion over Figures 4-29 and 4-30, in which a secondary datum axis or datum plane constrains only one rotational degree of freedom. How does this work exactly? We're left to wonder how an axis that is capable of constraining 4 DOF's only constrains one.
I think that pmarc is on the right track by questioning things, and exploring what the datum would be (if any) if the surface was irregular. I would say that if an irregular surface was referenced as a secondary datum feature, the datum would be a plane/line/point combination as defined in Figure 4-3. But exactly how that datum constrains only certain degrees of freedom, I'm not sure. The only way I've been able to make sense of it is to forget about the datums, and focus solely on the datum feature simulators. I agree with pmarc that when proposing this type of idea, one should prepare for attack ;^). It clashes with the core Y14.5 principle that a datum reference frame is a three-plane coordinate system derived from datums.
The way I like to look at it is that the reference frame is the "space" that the datum feature simulators are defined in. The coordinate system can be placed anywhere in this reference frame - it is arbitrary. The datums are arbitrary as well - they are only a conceptual convenience. This is why there are so many examples in Y14.5 in which the datums are difficult to figure out, or seem arbitrary. Figure 4-26 with the datum axis derived from a hole pattern is one of the worst. Don't get me started on that one!
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
The hole pattern seems to be a very functional type of datum. What are we trying to do, define functional requirements, or make things easy to check? We can't always have both. I hear it all the time, the management always says they want both: quality and schedule, it is pretty obvious to me which drives and which suffers.
Frank
Is it not what we have been striving for?
Frank,
I was always wondering how car industry was doing it for last 100 years.
To make sure you have good wheel, you have to check runout of the rim in relation to pattern of 4 or 5 conical holes used to bolt the wheel to the car.
Has anyone ever seen a blueprint?
Tapered cones is something always debated here, but has long been the foundation of the machine cutting tool industry. It was always an acceptable datum to me, I did not need ASME's OK to see that.
Let me explain further.
I don't have an issue with a hole pattern being specified as a datum *feature*. I agree that many parts mate this way and therefore referencing the holes together makes sense and captures the functional requirement. No problem there.
My problem is with the *datum* that Figure 4-26 shows as being extracted from the pattern of holes. The datum is described as an axis, which does not make sense.
Going by the feature types in Figure 4-3, the pattern of 4 parallel cylindrical holes falls into the category of Linear Extruded Shape (f). Thus the datum should be an axis and center plane. The axis alone would only control the X and Y degrees of freedom and would be insufficient to control w (clocking). I can't begin to count the number of questions I have heard over the years, on the meaning of the "datum axis" in Figure 4-26 (and the similar figure in Y14.5M-1994).
Even if we use the correct datum type in Figure 4-26, I still question the usefulness of the datum. Section 4.12.3 describes the pattern of datum feature simulators based on virtual condition boundaries, which is great. Then it states that the origin of the datum reference frame, which is based on the datums, is established either at the center of the pattern or at any other location defined with basic dimensions. In other words, the datum feature simulators are the important entities and the datums and DRF are just reference entities tacked on for convenience.
The wheel with 4 or 5 conical holes fitting simultaneously is a different can of worms.
Evan Janeshewski
www.axymetrix.ca
People were making wheels and bolting them to the cars/carts before GD&T was invented.
And yet in 21st century part that is produced literally by millions for several decades is still considered nuisance, can of worms, etc. Isn’t that a shame that we can figure the way how to make and inspect part, we just cannot figure out how to draw in on the piece of paper?
Is it just me thinking that today’s GD&T is suffering from severe disconnect from reality?
This is definitely subject for separate thread, but could it be the reason for today’s slow rate of GD&T adoption?
Sorry, this isn’t Friday yet; I must be getting grumpy ahead of time.
So it's not that we shouldn't apply GD&T here, it's just a challenging application for DRF establishment.
Evan Janeshewski
www.axymetrix.ca
How is it different from my statement? And how does it help with GD&T issues?
I suspect I will never be able to convince you this way. Apparently you and I were changing tires on different cars, so we have different feelings about it. There are several designs out there. Have you ever seen wheels that are first roughly located by pins mounted to the hub and then bolted down with tapered screws?
Here is another automotive application: truck half-axle being mounted and centered using tapered holes/fasteners. Feel free to deny.
And I was not challenging your statement in any way.
But that's the fun of these discussions. I await the insights about the recent wheel runout question.
John-Paul Belanger
