Maximum temperature material SA-106 Gr B by ASME Section VIII Div 2
Can the material SA-106 Gr B be used by a manufacturer to manufacture a vessel according to ASME Section VIII DIV 2, If the design temperature is 750°F? Where can I find the maximum temperature for the material SA-106 GrB according to ASME Section VIII Div 2?
Thank You
Thank You
RE: Maximum temperature material SA-106 Gr B by ASME Section VIII Div 2
Cheers,
gr2vessels
