Calculating the Poisson's for a material ratio using percentages of strain at break.
Hello
I have been provided a data sheet for laser-sintered polyamide. It had the values for percentages of axial and transverse strain at break.
I have tested the mechanical properties of the actual material, but i want to calculate the Poisson's ratio using the provided values in the data sheet for computational FEA.
I want to make sure that by dividing the proivided transverse strain at break by the axial strain at break, i will get the Poisson's ratio for the laser-sintered polyamide.
Thank you
Thank you
RE: Calculating the Poisson's for a material ratio using percentages of strain at break.
