combining models
combining models
Hi all,
I was just wondering if anyone know's how to combine 2 models into one so that they can interact. Both are orphan meshes. They are 2 seperate bones that make a joint. Building a part in abaqus is not an option nor is importing it as a part.
Any suggestions would be greatly appreciated
RE: combining models
So create one inp file with the 2 orphan meshes.
*Part, name=bone1
*Node
*Element, type=...
*End Part
*Part, name=bone2
*Node
*Element, type=...
*End Part
Then import that inp file in CAE and then create your interactions, boundary conditions, etc.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
I just figured out what I needed to do. You actually can put the 2 models together just by going into Model> copy object. Then you can select what you want and make a new model that has both orphan meshed models in it.
