Need help choosing an adhesive
First alittle about the application. The adhesive is for a transducer. The adhesive will bond Carbon fiber to neoprene foam. The glue should be dampning, strong, and flexible while providing excellent sealing properties. I have attached an image of the application. The carbon fiber is clearly visible and the rubber sticks right behind it. as you can see there is a white "blooming" whihch leads me to think it is urethane. Although I will need a urethane adhesive with all of the above properties. Does anyone know of any brand or other adhesives I can try.
RE: Need help choosing an adhesive
There are flexible epoxy adhesive formulations...which are less flexible than some of the other types mentioned, but much stronger.
